Quick and easy mastering settings
A few years ago I used to use some basic settings that mastered an audio track I created. It was somethinb g like Noprmalisatio and a bass and treble boost.
I can’t find nthise settings any more has anyone got any like that? (I am a very basic amateur muisican recording as you see!)
Realtime “Bass and treble” now only takes 4 clicks to navigate to …
realtime B&T
Normalize is in the old effect menu …
Effect > Volume and Compression > Normalize
OK but wasn’t there some other steps as well as bass and treble boost?
You mentioned normalize. There’s two different types of normalization now …
The old one … https://manual.audacityteam.org/man/normalize.html
and the new one … https://manual.audacityteam.org/man/loudness_normalization.html
