Questions about Audacity 4 before upgrading from 3
Hello!
Does the new version (Audacity 4.0.1) have the following tools: Music/Vocal separation & tempo/pitch change? I read from somewhere, that the new version wouldn’t have the tempo changing tool, which is kinda a disappointment if it is so. I’m wondering if I should stay on Audacity 3, or should I download the new version?
My advice is to download AU4 and play with it, but continue to use AU3 for real work. You can have both installed. On Mac you can have both running at the same time. Switch to AU4 when and if it meets your needs.
I don’t know. But from what I read in this forum there are more features missing than present. If you want really to do serious work with Audacity, I suggest you stay with version 3.x for a while now.
You may install version 4 besides version 3 - they don’t hurt each other. But you need to know that projects you made in version 4 can not be opened by version 3 (the other way works).
