i recorded a song and did it really well and then listened to it and it sounded ok but the vocals werent there just and i wanted to go back in and gain the voume on my voice track…
is there any way that i can go back into one of my sound files and gain the voulme on some things??
Audacity Projects allow you to work on multiple tracks and adjust them individually. Once you have mixed the project down to a normal audio file you can’t.
The mix-down is a bit like baking - once a cake is baked you can’t un-bake it.
…as a Project. The AUP file is just the project manager file. Projects have lots of files with different jobs, which is why it’s a pain to try and move one.
You also need to know that Projects do not save UNDO.
