Question about this software
I need to transfer some audio files from my Digital Recorder to my laptop and im also needing to know how I can slow my recordings down using this audacity software? Any help would be appreciated. Thanks!
Slowing down isn’t a serious problem. Use Effect > Change tools. Change-Speed, Change-Pitch, and Change-Tempo.
Transferring the files is much more of a problem. Connect the recorder and mount it as a storage device or get a card reader and walk the recorder’s storage card over to the computer (sneaker-net).
If you can’t do it digitally, the analog methods are much messier.
