Hi. I was looking at a mic called: Samson Go Mic Compact USB Microphone - Plug n’ Play
http://www.amazon.com/Samson-Mic-Compact-USB-Microphone/dp/B001R76D42/ref=sr_1_1?ie=UTF8&qid=1367101701&sr=8-1&keywords=Samson+Go+Mic+Compact+USB+Microphone+-+Plug+n’+Play
Does anyone know if I can use this microphone to record when it is not plugged into the computer? For example, can I record something on it and then transfer it to my computer later?
