Putting my vocal on a track
Hi everyone. Brand new to this, and always wanted to put my voice on music. I have recorded and removed vocal on a track. What is the easiest way to put my vocal on that track. This is just a bucket list item for me. Thanks, Curtis
You can set up for overdubbing. You record your voice over a backing track or rhythm track. It produces two tracks, music and voice, and when you play them both together, it sounds like you’re singing over the music. You need a live microphone and headphones. You could use a laptop built-in microphone, for example, but the separate headphones are required.
https://manual.audacityteam.org/man/tutorial_recording_multi_track_overdubs.html
The setup is a little involved because you have to adjust Audacity to play and record perfectly at the same time.
