I have 3 mp3-files I would like to put together in one mp3-file. I tried it with Audacity, but it did not work. And I do not know what is wrong. Can you help me?
Thanks
Zoé
Using Audacity 2.0.3 installed from .exe installer on Windows Vista!
Were you able to import the files into Audacity? (File menu > Import > Audio)
Were you able to drag them into position with the time shift tool
After that, all you need to do is “File > Export”.
By the way, I deleted your other topic about not being able to post.
