Pure Buss Audio
This is a general question about Audacity and where the windows 10 audio signal comes from.
When I use Audacity to record live audio on my desktop (not microphone) it seems that Audacity is seeing audio downstream from any system volume control, eq, etc. I know this because the recording level in Audacity changes with the system volume / tone controls. So this is probably normal but I am wondering if there is a way to setup Audacity so that it sees audio straight off the buss before it goes to any system volume / tone controls?
I think this is possible somehow as I have a device made by Audio Engine that takes the signal straight off the buss (USB) and then sends it to my home theater system (in this case).
So how do I get Audacity to do the same?
Audacity 2.1.1
Windows 10 Pro
If your question is simply recording what’s playing on the computer…
http://manual.audacityteam.org/o/man/tutorial_recording_computer_playback_on_windows.html
I believe the special driver method does not go through the sound card.
See “WASAPI loopback recording” http://manual.audacityteam.org/o/man/tutorial_recording_computer_playback_on_windows.html
