Projects Save
MacOS 10.13.6 … Audacity 2.4.2.
I’m trying to do an actual simple editing job. Be very afraid.
Step one, get rid of all the little clocks. I don’t know how I did it either, but Google knew.
There is no split and push, is there? Pick a point in the mid-waveform, click/split and push the right-hand portion later. Make a hole.
Projects don’t save timeline volume sliders, do they?
I didn’t check the panning controls. Do those settings vanish, too?
Any way to intentionally synchronize/link SELECT and SOLO?
I didn’t get very far. I’ll find more.
:smiley:
As far as I’m aware, the only way to turn that on or off is “Tracks menu > Sync-Lock Tracks”.
Other than removing it completely, do you have any suggestions for improvement?
It’s two steps:
  1. Split (Edit Menu: Audio Clips - Audacity Manual)
  2. Push (Time Shift Tool - Audacity Manual)
In Audacity 2.4.2, yes they do.
No. In Audacity 2.4.2 they are saved in the project.
I don’t know what you mean.
Very good idea. :smiley:
I need to go back through some of the keystrokes again. I wasn’t taking notes. I was goal oriented. Sorry, “orientated.”
