Projects cannot be saved to FAT Drives
Good Morning,
We use Cloud Drive Mapper to map our OneDrive for Staff and students cannot save locally. When the try to save a project they are greeted with the error. Is there anything we can do ?
Thanks
If you can save locally temporarily, I believe you can copy to OneDrive, and then copy it back to a local drive before re-opening it.
