Hey.
My project won’t work anymore because an error message says the .AU files are missing (audacity can’t find it).
The thing is, the project is sabes in the same original location, there is the _DATA file next to it.
It das all working fine. I saved it and closed it. Now audacity can’t find the files. The .AU files, when solo imported are distorted.
Any fix please?
Thank you
