For some reason Audacity is not opening anymore.
I already tried re-installing it, but it didn’t work.
It’s really weird since I was using it last night and nothing went wrong with it.
We need the information from the pink band above this thread. Which Audacity? Which Windows?
Download Audacity 2.1.0
Windows 8
Try reinstalling Audacity from the recommended installer (http://web.audacityteam.org/download/windows)
During the installation, look out for the option to “Reset Preferences” and select that option.
It worked!
Thanks
Thanks for letting us know.
Marked as solved…
