I make a lot of mistakes while recording, so I quickly stop recording, hit CONTROL+Z and then R again to record. This is usually in less than half a second.
Sometimes I get this error message:
ALSA lib pcm_dsnoop.c:612:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib audio/pcm_bluetooth.c:1614:(audioservice_expect) BT_GET_CAPABILITIES failed : Input/output error(5)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4541
** (Audacity:30728): CRITICAL **: os_bar_hide: assertion `OS_IS_BAR (bar)' failed
(Audacity:30728): Gtk-CRITICAL **: IA__gtk_widget_hide: assertion `GTK_IS_WIDGET (widget)' failed
** (Audacity:30728): CRITICAL **: os_bar_set_parent: assertion `OS_IS_BAR (bar)' failed
Expression 'err' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3286
Expression 'ContinuePoll( self, StreamDirection_In, &pollTimeout, &pollCapture )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3813
Expression 'PaAlsaStream_WaitForFrames( stream, &framesAvail, &xrun )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4185
Other times I get this message:
ALSA lib pcm.c:7339:(snd_pcm_recover) underrun occurred
Thanks in advance!
