Product request: Chain Shortcuts
Hello Audacity Users. Hello also to the development team.
In recent months I have discovered the joys of working with effects chains. It has made my busy audio editing work much simpler.
I know I have mentioned it before in a previous post, but may I put in a product request, that keyboard short cuts could be applied to each individual effect chain.
For example, my voice post-processing recipe could be simply P, and my breath reduction setting B.
Again, thank you for considering my requests. I understand there are many demands for developments.
Kind regards
James the Radio Trainer
Chains is listed in the keyboard shortcuts in Audacity Preferences.
One problem is you have to miss the existing shortcuts—or reroute them.
P is already assigned to Play/Pause, so that’s an important one.
They don’t allow you to select a specific named Chain in one key press, which is what I think Trainer is asking for.
This Proposal that Gale was a champion of relates to this:
https://wiki.audacityteam.org/wiki/Proposal_Binding_Particular_Parameters_of_Effects_to_Hot-Keys
Hi
Yes, thank you Steve for clarifying my question. :slight_smile:
I would love to be able to assign an individual keyboard short cut to each of my chains. For example, my voice processing chain (which I use a lot) contains several effects. A single keystroke would be very useful for this one chain.
I looked at Gail’s suggestion (assignable short cuts for individual presets within effects) which is certainly very useful. However, applying short cuts to individual chains would meet both needs - presets within effects (these can be saved as chains) and chains of multiple effects.
Thank you all for your additional comments. and I live in hope for this feature.
James the trainer
You could probably do this with some form of scripting like AutoIT3 or AutoHotKey. I run individual chains by voice using Dragon NaturallySpeaking and AutoIT3 but I’m still using a highly customized version of 2.0.1.
