I am having an issue with Saffire Pro 14 Firewire interface on Windows 8 with Audacity…
On record there is no audio coming through or picked up, despite the Input sources being correctly set to the Saffire Pro and I am wondering if others have this issue. I have seen a couple of threads on this but no definitive answer and I am thinking that due to the Saffire Pro 14 being a ASIO interface, might be incompatible with Audacity for recording but can’t quite believe this is the case.
Also if I try to record using a hard wired method i.e. from the Saffire Pro 14 outputs into the computers mic line in (and setting Audacity accordingly), i just get white noise regardless of any settings.
There is not a problem with the Saffire or FW card as the interface records fine with other audio software e.g. Adobe Audition.
If any one can help/advise that would be great.
