Problems with Multiple Recordings
I have a Windows 8 computer and am using Audacity 2.0.5 from the .exe installer. I can record one stereo line just fine, but when I go to record another, unless the first is mute, it won’t record. It says it is recording, but there is no sound. I am using headphones, so it’s not interference. HELP!!
~Keryshna
What settings are available in the device toolbar and which settings are selected?
When you say there is no sound, do you mean that it is producing a flat line recording on the second track?
It has some spikes, but most of it is flat. It works fine if the first track is muted. It’s only when I try to listen to the first track and record at the same time that it acts up.
Follow the steps here to turn off all Windows and sound card “enhancements”:
http://manual.audacityteam.org/o/man/faq_recording_troubleshooting.html#enhancements .
While in Windows “Sound” as per the link above, click the main Communications tab, then under “When Windows detects communications activity:”, choose “Do nothing”.
If that does not help then you may not have correct drivers for your computer sound device. What is the make and model number of the computer?
