problems with gain control when importing vinyls
i use the older ION TAPE 2 PC DECK to import my tapes to my xp laptop(it has a GAIN control at the rear) howevever, some people when using the older ION RECORD DECK to import vinyls find they cannot control the INPUT level as there is no gain control on the record deck.its easy…connect the red & white RGB Wires from your ION record deck to the output phono sockets on the ION TAPE 2 PC deck & use it’s GAIN control, its simple.the sound quality of the older TAPE 2 PC DECK is astonishing,much better than the new hand held version/s in my opinion.
This is probably of most value posted in the “Recording Equipment” board, so topic moved.
