Problems with Adjustable Fade effect not appearing
Hey forum,
Recently, I discovered a wonderful effect in Audacity, known as Adjustable Fade. But occasionally (which pretty much means always, unless I am in a blank Audacity window), when I select portions of audio and accordingly look for the effect, it just isn’t there. Instead, it skips right to Clip Fix.
In short, Adjustable Fade is not always listed when I open Audacity.
This is a minor problem, but any help would be appreciated. Thanks!
Please, always tell us your version of Audacity (all three number, see the pink panel at the top of the page).
That is where it is meant to be.
Have you tried creating a keyboard shortcut for Adjustable Fade in Keyboard Preferences? Then just type the shortcut when you want Adjustable Fade.
