Problems with 3.7.5 release
Since upgrading to 3.7.5, I have found that the process of importing Flac files & exporting them as mp3’s, is no longer functional. I have been using this process for a long time, using Audacity, and always export my files as a constant 192kbps. Since the upgrade, exported files are garbled & completely unusable.
I have repeatedly re-tested the process, with the same results every time, I have now reverted back to the 3.7.4 release, and the problem is immediately corrected. I will therefore suspend any future upgrades, until I know that these errors have been recognised & corrected.
Best Regards,
Intarest.
