Problems while recording
Hi,
I have some problems while recording with my microphone.
I use Windows Vista, have an Tascam interface (24 bit, connected with USB) and am currently using Audacity version 2.05.
Sometimes recording goes perfect, but very often this happens:
*I can’t recording at all
*OR I record a secund voice and then the program automaticly record the first voice again together with the new voice. Sometimes this happens in the middle of a recording without changing anything.
*OR A lot of noises appear while recording (not always from the beginning, but while recording without changing anything).
When I just wait for a couple of minutes then it works again perfect for a short time. And then problems start again.
Somebody can help me?
Thanks!
Nelly
P.S.: Sorry for my bad English
I think you are not recording the mixer. There are settings where you can record everything playing on the computer instead of restricting the recording to just the mixer connection. People get these settings confused all the time because those special settings are the ones used to record YouTube or other internet sound.
You can set Audacity to record YouTube or set to record overdubbing. Two different settings.
http://manual.audacityteam.org/o/man/tutorial_selecting_your_input.html
I don’t think that’s the problem.
Settings are right.
And I can start recording without any problem, but then suddenly (without changing the settings) it doesn’t work correct anymore.
Maybe my PC is just too old? Problems with intern memory?
Thanks for replying anyway.
Nelly
Go through all these tips here Audacity Manual .
The first thing you could try is to use a higher “Audio to buffer” in Audacity Recording Preferences and check any buffer settings in Tascam.
Also, connect to an empty USB port on the computer - do not connect to a USB hub that has other USB devices connected to it.
Go to the Tascam web site and make sure you have the latest drivers and firmware meant for Vista and your particular interface.
