Problems to record audio to Audacity after Windows 10 update to 1803/1809
I have found out that Microsoft has changed the audio connection from Stereo Mix to
Microphone from the Windows 10 update to 1803/1809, without any information.
That means that you have to do following to fix it for Audacity 2,3:
Start- Computer Adjustments- Security- Microphone- Change
(accept microphone for this unit)- On
Now Stereo Mix will work for Audacity, and you can record sound from the web or other units,
but there is still an echo problem when you listen to audio from your speakers, so you have to
switch of your Stero Mix if you are not recording!.
That’s all!
Good luck!
Thanks for the tip. We have already added a note about the privacy settings at the top of the Windows forum board:
Microphone problems after the Windows 10 April 2018 Update
