Problems recording tracks
Hi
I am using version 2.0.5 on an HP desktop.
Occasionally when I record a new vocal track, the sound will be extremely “choppy” if there is a track already in existence. Up until now I have solved the issue by re-installing Audacity but this has so far proven to have been only a temporary fix.
Any ideas on what might be going on?
My settings for recording are,
Line in
Mono
44100 Hz
If your computer uses Windows, try both the “MME” and the “Direct Sound” settings in the (“host”) device toolbar to see if one gives better results than the other.
I will try that - thanks!!!
By the way - AUDACITY IS AWESOME!!!
I use it to record narratives for audio books, and I produce a daily syndicated radio show. I was trained with ProTools and Audacity runs circles around it in some respects.
