I’m fairly new to compiling from source, but seeing as that appears to be the only way to get the latest Audacity in Debian Squeeze I had a go at it. Followed the instructions, but of course it didn’t work and I have no idea what to do now. Here is the config log. ANy ideas what I need to do now or is there an easier way to install Audacity 2.x in Debian Squeeze?
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.68. Invocation command line was
$ ./configure
## Platform. ##
hostname = debian
uname -m = x86_64
uname -r = 2.6.32-5-amd64
uname -s = Linux
uname -v = #1 SMP Sun May 6 04:00:17 UTC 2012
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
## Core tests. ##
configure:2444: checking for gcc
configure:2460: found /usr/bin/gcc
configure:2471: result: gcc
configure:2700: checking for C compiler version
configure:2709: gcc --version >&5
gcc (Debian 4.4.5-8) 4.4.5
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2720: $? = 0
configure:2709: gcc -v >&5
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 4.4.5-8' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.4 --enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4 --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --with-arch-32=i586 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.4.5 (Debian 4.4.5-8)
configure:2709: gcc -V >&5
gcc: '-V' option must have argument
configure:2720: $? = 1
configure:2709: gcc -qversion >&5
gcc: unrecognized option '-qversion'
gcc: no input files
configure:2740: checking whether the C compiler works
configure:2762: gcc conftest.c >&5
configure:2766: $? = 0
configure:2814: result: yes
configure:2817: checking for C compiler default output file name
configure:2819: result: a.out
configure:2825: checking for suffix of executables
configure:2832: gcc -o conftest conftest.c >&5
configure:2836: $? = 0
configure:2858: result:
configure:2880: checking whether we are cross compiling
configure:2888: gcc -o conftest conftest.c >&5
configure:2892: $? = 0
configure:2899: ./conftest
configure:2903: $? = 0
configure:2918: result: no
configure:2923: checking for suffix of object files
configure:2945: gcc -c conftest.c >&5
configure:2949: $? = 0
configure:2970: result: o
configure:2974: checking whether we are using the GNU C compiler
configure:2993: gcc -c conftest.c >&5
configure:2993: $? = 0
configure:3002: result: yes
configure:3011: checking whether gcc accepts -g
configure:3031: gcc -c -g conftest.c >&5
configure:3031: $? = 0
configure:3072: result: yes
configure:3089: checking for gcc option to accept ISO C89
configure:3153: gcc -c -g -O2 conftest.c >&5
configure:3153: $? = 0
configure:3166: result: none needed
configure:3188: checking for C compiler vendor
configure:3212: gcc -c -g -O2 conftest.c >&5
conftest.c: In function 'main':
conftest.c:15: error: 'thisisanerror' undeclared (first use in this function)
conftest.c:15: error: (Each undeclared identifier is reported only once
conftest.c:15: error: for each function it appears in.)
configure:3212: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| /* end confdefs.h. */
| int
| main ()
| #if !(defined(__ICC) || defined(__ECC) || defined(__INTEL_COMPILER))
| thisisanerror;
| #endif
| return 0;
| /* confdefs.h */
| int
| main ()
| #if !(defined(__xlc__) || defined(__xlC__) || defined(__IBMC__) || defined(__IBMCPP__))
| thisisanerror;
| #endif
| return 0;
| /* confdefs.h */
| int
| main ()
| #if !(defined(__PATHCC__) || defined(__PATHSCALE__))
| thisisanerror;
| #endif
| return 0;
configure:3212: $? = 0
configure:3219: result: gnu
configure:3270: checking for gcc
configure:3297: result: gcc
configure:3526: checking for C compiler version
configure:3535: gcc --version >&5
configure:3546: $? = 0
configure:3535: gcc -v >&5
Thread model: posix
configure:3535: gcc -V >&5
configure:3546: $? = 1
configure:3535: gcc -qversion >&5
gcc: no input files
configure:3550: checking whether we are using the GNU C compiler
configure:3578: result: yes
configure:3587: checking whether gcc accepts -g
configure:3648: result: yes
configure:3665: checking for gcc option to accept ISO C89
configure:3742: result: none needed
configure:3826: checking for g++
configure:3856: result: no
configure:3826: checking for c++
configure:3826: checking for gpp
configure:3826: checking for aCC
configure:3826: checking for CC
configure:3826: checking for cxx
configure:3826: checking for cc++
configure:3826: checking for cl.exe
configure:3826: checking for FCC
configure:3826: checking for KCC
configure:3826: checking for RCC
configure:3826: checking for xlC_r
configure:3880: checking for C++ compiler version
configure:3889: g++ --version >&5
./configure: line 3891: g++: command not found
configure:3900: $? = 127
configure:3889: g++ -v >&5
configure:3889: g++ -V >&5
configure:3889: g++ -qversion >&5
configure:3904: checking whether we are using the GNU C++ compiler
configure:3923: g++ -c conftest.cpp >&5
./configure: line 1650: g++: command not found
configure:3923: $? = 127
| /* confdefs.h */
| int
| main ()
| #ifndef __GNUC__
| choke me
| #endif
| return 0;
configure:3932: result: no
configure:3941: checking whether g++ accepts -g
configure:3961: g++ -c -g conftest.cpp >&5
configure:3961: $? = 127
| /* confdefs.h */
| int
| main ()
| return 0;
configure:3976: g++ -c conftest.cpp >&5
configure:3976: $? = 127
| /* confdefs.h */
| int
| main ()
| return 0;
configure:3992: g++ -c -g conftest.cpp >&5
configure:3992: $? = 127
| /* confdefs.h */
| int
| main ()
| return 0;
configure:4002: result: no
configure:4030: checking how to run the C++ preprocessor
configure:4057: g++ -E conftest.cpp
./configure: line 1687: g++: command not found
configure:4057: $? = 127
| /* confdefs.h */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| Syntax error
| /* confdefs.h */
| #ifdef __STDC__
| #else
| #endif
| Syntax error
configure:4057: /lib/cpp conftest.cpp
cpp: error trying to exec 'cc1plus': execvp: No such file or directory
| /* confdefs.h */
| #ifdef __STDC__
| #else
| #endif
| Syntax error
| /* confdefs.h */
| #ifdef __STDC__
| #else
| #endif
| Syntax error
configure:4096: result: /lib/cpp
configure:4116: /lib/cpp conftest.cpp
configure:4116: $? = 1
| /* confdefs.h */
| #ifdef __STDC__
| #else
| #endif
| Syntax error
| /* confdefs.h */
| #ifdef __STDC__
| #else
| #endif
| Syntax error
configure:4146: error: in `/home/don/audacity':
configure:4148: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details
## Cache variables. ##
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=no
ac_cv_env_AVCODEC_CFLAGS_set=
ac_cv_env_AVCODEC_CFLAGS_value=
ac_cv_env_AVCODEC_LIBS_set=
ac_cv_env_AVCODEC_LIBS_value=
ac_cv_env_AVFORMAT_CFLAGS_set=
ac_cv_env_AVFORMAT_CFLAGS_value=
ac_cv_env_AVFORMAT_LIBS_set=
ac_cv_env_AVFORMAT_LIBS_value=
ac_cv_env_AVUTIL_CFLAGS_set=
ac_cv_env_AVUTIL_CFLAGS_value=
ac_cv_env_AVUTIL_LIBS_set=
ac_cv_env_AVUTIL_LIBS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_GTK_CFLAGS_set=
ac_cv_env_GTK_CFLAGS_value=
ac_cv_env_GTK_LIBS_set=
ac_cv_env_GTK_LIBS_value=
ac_cv_env_JACK_CFLAGS_set=
ac_cv_env_JACK_CFLAGS_value=
ac_cv_env_JACK_LIBS_set=
ac_cv_env_JACK_LIBS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBMAD_CFLAGS_set=
ac_cv_env_LIBMAD_CFLAGS_value=
ac_cv_env_LIBMAD_LIBS_set=
ac_cv_env_LIBMAD_LIBS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_LIBTWOLAME_CFLAGS_set=
ac_cv_env_LIBTWOLAME_CFLAGS_value=
ac_cv_env_LIBTWOLAME_LIBS_set=
ac_cv_env_LIBTWOLAME_LIBS_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_PORTAUDIO_CFLAGS_set=
ac_cv_env_PORTAUDIO_CFLAGS_value=
ac_cv_env_PORTAUDIO_LIBS_set=
ac_cv_env_PORTAUDIO_LIBS_value=
ac_cv_env_PORTSMF_CFLAGS_set=
ac_cv_env_PORTSMF_CFLAGS_value=
ac_cv_env_PORTSMF_LIBS_set=
ac_cv_env_PORTSMF_LIBS_value=
ac_cv_env_SAMPLERATE_CFLAGS_set=
ac_cv_env_SAMPLERATE_CFLAGS_value=
ac_cv_env_SAMPLERATE_LIBS_set=
ac_cv_env_SAMPLERATE_LIBS_value=
ac_cv_env_SBSMS_CFLAGS_set=
ac_cv_env_SBSMS_CFLAGS_value=
ac_cv_env_SBSMS_LIBS_set=
ac_cv_env_SBSMS_LIBS_value=
ac_cv_env_SNDFILE_CFLAGS_set=
ac_cv_env_SNDFILE_CFLAGS_value=
ac_cv_env_SNDFILE_LIBS_set=
ac_cv_env_SNDFILE_LIBS_value=
ac_cv_env_SOUNDTOUCH_CFLAGS_set=
ac_cv_env_SOUNDTOUCH_CFLAGS_value=
ac_cv_env_SOUNDTOUCH_LIBS_set=
ac_cv_env_SOUNDTOUCH_LIBS_value=
ac_cv_env_VAMP_CFLAGS_set=
ac_cv_env_VAMP_CFLAGS_value=
ac_cv_env_VAMP_LIBS_set=
ac_cv_env_VAMP_LIBS_value=
ac_cv_env_WIDGETEXTRA_CFLAGS_set=
ac_cv_env_WIDGETEXTRA_CFLAGS_value=
ac_cv_env_WIDGETEXTRA_LIBS_set=
ac_cv_env_WIDGETEXTRA_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_objext=o
ac_cv_prog_CXXCPP=/lib/cpp
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=no
ax_cv_c_compiler_vendor=gnu
## Output variables. ##
AFTERBUILD=''
AUDACITY_NAME=''
AVCODEC_CFLAGS=''
AVCODEC_LIBS=''
AVFORMAT_CFLAGS=''
AVFORMAT_LIBS=''
AVUTIL_CFLAGS=''
AVUTIL_LIBS=''
BUILD_LDFLAGS=''
CC='gcc'
CDEPEND=''
CFLAGS='-g -O2'
CFLAG_VISIBILITY=''
CONFIGHEADER=''
CPPFLAGS=''
CXX='g++'
CXXCPP='/lib/cpp'
CXXFLAGS=''
DEFS=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
EXTRAINSTALLTARGETS=''
EXTRAOBJS=''
EXTRATARGETS=''
EXTRAUNINSTALLTARGETS=''
GREP=''
GTK_CFLAGS=''
GTK_LIBS=''
HAVE_GTK=''
HAVE_PKG_CONFIG=''
HAVE_VISIBILITY=''
INSTALL_DATA=''
INSTALL_PREFIX=''
INSTALL_PROGRAM=''
INSTALL_SCRIPT=''
JACK_CFLAGS=''
JACK_LIBS=''
LDFLAGS=''
LIBMAD_CFLAGS=''
LIBMAD_LIBS=''
LIBOBJS=''
LIBS=''
LIBSRC_BUILD=''
LIBTWOLAME_CFLAGS=''
LIBTWOLAME_LIBS=''
LOCAL_LIBS=''
LTLIBOBJS=''
MIMETYPES=''
OBJEXT='o'
OPTOBJS=''
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_URL=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PKG_CONFIG=''
PORTAUDIO_CFLAGS=''
PORTAUDIO_LIBS=''
PORTSMF_CFLAGS=''
PORTSMF_LIBS=''
PRECOMP_CFLAGS=''
SAMPLERATE_CFLAGS=''
SAMPLERATE_LIBS=''
SBSMS_CFLAGS=''
SBSMS_LIBS=''
SED=''
SHELL='/bin/bash'
SNDFILE_CFLAGS=''
SNDFILE_LIBS=''
SOUNDTOUCH_CFLAGS=''
SOUNDTOUCH_LIBS=''
VAMP_CFLAGS=''
VAMP_LIBS=''
WIDGETEXTRA_CFLAGS=''
WIDGETEXTRA_LIBS=''
WX_CONFIG=''
ac_ct_CC='gcc'
ac_ct_CXX=''
bindir='${exec_prefix}/bin'
build=''
build_alias=''
build_cpu=''
build_os=''
build_vendor=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='NONE'
host=''
host_alias=''
host_cpu=''
host_os=''
host_vendor=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
subdirs=''
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
configure: exit 1
