Long time user of Audacity, with no problems in the past. Adding labels to tracks now presents problems- query due to new version of Audacity. First track label will not join up with all the other labels, so that when labelled project is exported none of the tracks are labelled or saved as separate tracks.
When doing an Export Multiple, you can split your audio into several files based on Audacity tracks or based on Audacity labels. And there is an option to include any audio prior to the first label.
Please see the “Examples of use of labels with Export Multiple” near the bottom of this reference: Export Multiple - Audacity Manual
