J’ai un problème avec audacity. Je joue avec un casque avec un micro et j’aimerais savoir comment enregistrer ma voix et le jeu en même temps.
J’arrive à enregistrer la voix mais sans le son du jeu.
Merci de votre aide
Hello everybody,
I have a problem with audacity. I play with a headset including a microphone and i would like to know how to record my voice and the sound of the game in the same time.
On Vista/Windows 7 and Windows 8, you may not be able to unmute the mic. In that case go to the “Recording” tab of “Sound” in Windows, right-click over the mic > Properties, then click the “Listen” tab. Set Listen to send the mic input to your built-in sound device. Then record from stereo mix as above.
This does not work with a USB headset. It needs a headset with pink and green leads.
