problem with volume on exported MP3 file
I have a 4 track file , 1 music and 3 vocal
sounds fine on Audacity but when i export it to either Flac or MP3 the vocal volume is through the roof and , the music level is fine
when i exported it i chose mp3 , got the warning about stereo and 2 channels , thought that was ok
it works fine when i have only 2 tracks but with 4 its no use
any ideas what i am doing wrong ?
I am a new user and have onlt been using for a few days
thanks
jm
The music track is stereo and the voice tracks are mono?
Is everything you? You performed all the parts?
Can you post a screen shot of what your Audacity work window looks like when everything is loaded and ready to play?
https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
Isn’t the problem just that you need to turn down the gain on the vocal tracks using the -…+ gain slider to left of the blue waves? Mixing tracks is additive and increases volume unless the waveforms are opposites and cancel each other out.
