Problem with Distortion effect on Audacity for Windows
Hello.
I’ve found a bug, maybe. When I’ve tried to select presets in distortion effect, nothing changed.
Please, could You look on It?
Thank You.
Marco Oros
Probably this bug.
Sadly the bug has been present for over 2 years, so it is unlikely there will be a fix anytime soon :frowning:
If the presets are important for you, old versions of Audacity are available from FossHub.com.
