Problem with Commands Sequence
I use Audacity into GNU/Linux UbuntuStudio 16.04 LTS.
I upgraded to Audacity 2.2.0, and now I can not to use Commands Sequence with more than one file (as a batch typical process).
I can use Commands Sequence with the audio I have into the screen, only.
Somebody knows something about it??? Is it a bug???
Juan, from Chile.
If you’re referring to “Chains” (http://manual.audacityteam.org/man/chains_for_batch_processing_and_effects_automation.html), then it’s a bug. Unfortunately this bug was not spotted until shortly after 2.2.0 was released. The good news is that there is due to be a new release (2.2.1) in December, and it fixes this bug.
Yes, it’s about “Chains”.
Well, we have to wait for the final bug fix.
Thanks Steve!!!
