Problem with audio - loudness and bass (SOLVED)
Hi
i just opening old mp3 file ( because on my mp3 player and media player was problem with channels and the file looks quiet and no bass )
I open it in Audacity and file plays very nice - louder and with bass… Try to export to mp3 back but media player plays as was before - quiet and no bass .
Why is a difference, how can i export to have same level of sound ?
In taskbar Sound level is same for Media Player and Audacity
You can get that problem if your speakers or sound system has a problem.
Download and play this short sound test. You should be able to hear all four segments and in the right place although the last one may sound a little funny.
http://www.kozco.com/tech/LRMonoPhase4.wav
Test sound ok for the speakers.
Maybe is something with sound mapper ? Only if i play files in audacity they are louder and have more bass
then standard media player. Maybe is other codec used for audacity ?
( Koz you speak polish ? )
OK problem solved !
Someone change my media player equalizer !:slight_smile:
Topic can be closed.
Sorry for that.
