Problem recording stereo input from record player
I’m trying to record some vinyl records and then export them as digital FLAC files. However, when I record in stereo only the right channel records the proper music it should, the left channel only gets static. I know for sure that it is a stereo input because it worked properly for about 3 minutes and then switched to what I just described. I have tried recording in mono, but that only records the left channel so I end up with empty static. I know it’s not the OS because I also had this exact problem on windows and Linux. If the specifics matter I’m using a gemini gtt-5000pk record player that connects to my computer directly through a usb cable.
This is probably a Windows issue - sometimes Windows is default set to mono, you need to change that to stereo in your Sound Devices
