I have two *.aup files and this problem happens with both. I’ll describe the details of one. I’ve been using one of the files successfully for several weeks (the one referenced below). I created the other one today by copying and renaming in Windows. I used it successfully as well. Now this problem is happening and I can’t use either one.
In Windows File Explorer, the file is called “Bach 1079 – Largo – Violin.aup.
I get the same problem whether I double click on the .AUP file or choose it from Recent Files. First I get this error:
Couldn’t find the project data folder: “Bach Sonata 10079 – Largo – violin_data” NOTE the addition of “_data” at the end of the file name. After I click OK I get this error:
Could not load file: “C:LAS\Bach Sonata 1079 – Largo – violin.aup” The “_data” is not there.
Can I fix this or do I just need to re-create my projects from scratch?
tia
las
