In prior versions of Audacity, I used to be able to split tracks in half (such as Side 1 and Side 2) and export them to the same location (for example, C/Music). With 3.4, once Side 1 is exported, Side 2 also is exported to the same location but does not recognize the file type and shows no metadata, so is basically unusable. If you export the same file to another location (like a flash drive) there is no problem, so I have had to revert to sending the second side to the flash drive and then cutting and pasting into C drive. It seems like 3.4 is limiting one file per location when several files are in the project. Please restore the old functionality.
Using Export Multiple ?
Who does not recognize which file type ?
If you can be more specific, I can have a go a trying to reproduce you difficulty.
Note that older versions of Audacity are available here: Old Audacity versions download
