I’ve got this problem with 2 mp3 files. They are separated by a quite brief silence (about 1sec) which I would like to eliminate, so that the second file starts playing immediately after the first. Just to give some real life meaning to this, the two files are the 3rd and 4th movements of Beethoven’s 5th symphony, which anybody familiar with this work would know that the last movement follows immediately on the previous one with no silence between them.
I had a look in the wiki and tried to join the two files and then put a label in the 4th movement to separate them conceptually but not physically (if you know what I mean). But this doesn’t seem to work.
According to eye3D (a linux ID3-tag editor, people here probably know about), the files are MPEG1, Layer III [ ~226 kb/s @ 44100 Hz - Joint stereo ]. This doesn’t mean a whole lot to me but I would like to retain this bitrate on export. I understand the default bitrate is 128 and, apparently, the bitrate can be changed before LAME is evoked. I could be way at sea on this stuff so please bear with me.
My version of Audacity is 1.3.7 and the OS is Ubuntu 9.04.
Any pointers on how I should proceed would be much appreciated, TIA
