I just downloaded audacity 2.0.4 the other day. I have windows 7. I just wanted to know if I can print out the manual for this. Thanks.
You can, but it will be extremely time consuming as there are over 200 pages and you will only be able to print them out one at a time.
Best thing is, if you installed Audacity from the recommended Windows installer, you will have the manual installed. When you need to look something up, do so from the Audacity Help menu > Manual. If you need a hard copy of that page, use the “Print” option in your web browser (probably in the “File” menu).
Also note that most web browsers allow you to save “favourites” or “bookmarks”, so you may not actually need to waste paper and ink - just bookmark the relevant page.
ok thank you Steve.
