Hi everybody, is there a way to print out the complete user manual?
Thanks
No convenient way to print more than a page at a time.
Single pages can be printed from most web browsers.
The up-side is that you’ve saved wasting $50 of ink on something that you’re unlikely to read cover to cover - the manual is mostly reference material. Many of the tutorials are single page articles, which makes them easy to print.
If you use Adobe Acrobat you may be able to save the site http://manual.audacityteam.org/ as a PDF. The PDF may not have all the features of the HTML pages such as clickable image maps or tooltips. Then you can print the PDF if you have enough ink - there are over 250 pages.
