I was just about to finish and export my next radio show (volunteer dj at community station) and was adding an effect to my voice and bam!
File crashed, it was a big file, I had saved the data file as I saved the project but the show.aup file is empty of audio. The edits, clips, fades, etc are all there but no sound? I tried the auto recovery option when that window popped up but no luck. Says all the files are orphaned?
I’ve read around the forum for awhile and it sounds like the many hours I put into the show may be lost! Or I need to rename all the data files with the automator application to put them in numerological order or something? I’m not a super tech guy so that all sounds difficult.
Anyone have any ideas to save one of my best shows to date?
Here is the log
11:42:28: Audacity 2.2.2
11:42:28: Trying to load FFmpeg libraries…
11:42:28: Trying to load FFmpeg libraries from default path, ‘/Library/Application Support/audacity/libs/libavformat.55.dylib’.
11:42:28: Checking for monolithic avformat from ‘/Library/Application Support/audacity/libs/libavformat.55.dylib’.
11:42:29: avformat not monolithic
11:42:29: Loading avutil from ‘/Library/Application Support/audacity/libs/./libavutil.52.dylib’.
11:42:29: Loading avcodec from ‘/Library/Application Support/audacity/libs/./libavcodec.55.dylib’.
11:42:29: Loading avformat from ‘/Library/Application Support/audacity/libs/libavformat.55.dylib’.
11:42:29: Actual avutil path /Library/Application Support/audacity/libs/./libavutil.52.dylib
11:42:29: Actual avcodec path /Library/Application Support/audacity/libs/./libavcodec.55.dylib
11:42:29: Actual avformat path /Library/Application Support/audacity/libs/libavformat.55.dylib
11:42:29: Importing symbols…
11:42:29: All symbols loaded successfully. Initializing the library.
11:42:29: Retrieving FFmpeg library version numbers:
11:42:29: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
11:42:29: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
11:42:29: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
11:42:29: FFmpeg libraries loaded successfully.
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e0000028.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e0000044.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e000006d.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e00000c0.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e00000dd.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e00000df.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e0000101.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e0000113.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e000013f.au’
11:42:56: Warning: Orphan block file: ‘/Users/admin/Desktop/The next show_data/e00/d00/e0000162.au’
and so on lots and lots of Ophan block file warnings
