Hi, I apologize if this is in the wrong place. I use audacity a lot for creating and mixing music, and for analyzing spirit communication recordings.
I think i have found a small bug in the software of audacity version 2.3.1, which is installed on my msi laptop running windows 10 64bit.
When i highlight a section of audio and select the effect ‘tempo’, if i click the option to ‘preview’ a tempo change, the audio plays back at normal speed, and the highlighting disappears.
I have captured a short desktop video of this, which shows it better than i can explain, and the link for this is:
Ahhh - so that’s the trick to make it fail - doing that I see the same symptoms (I hadn’t done that previously)
a) preview plays at normal speed
b) selection disappears on completion of the preview (and it’s not just a visual disappareance - the selection is lost)
I get the same with Change Pitch - bit not with Sliding Stretch (there is no ‘tick’ in box to select ‘use high quality stretching)’
I tested this on the alpha testbuild we have for the upcoming 2.3.2 = so I’ll be looging this shortly.
Phew! Thanks guys, i was beginning to think I was the only one experiencing problems. Audacity is my go to for all my audio editing. the glitch is slowing me down a little, be nice to see it gone
We are currently planning to release 2.3.2 next month (provided no major bugs appear). But Release Candidates should be available for testing before that if you want to try it out.
Once again, many thanks Vamphyyre - good catch and thanks for the report
