Precise edit
Newbie-ish question. I have an existing audio file that I am playing back. While listening can a somehow mark where an edit or cut should begin and end?
Or put another way, what’s the easiest way to make multiple edits/cuts in the same file quickly and very accurately.
Thanks!
Can insert a split into the track, (don’t worry you can’t hear the join). Or add labels.
