Possible to Fix Playhead
I was wondering if it is possible to fix the playhead so it does not move, and instead the audio waveform moves behind it? If anyone knows where this setting is I would appreciate it.
Audacity 2.1.0
MacBook Pro
OS X 10.10.5
Thanks, gLaZe
Audacity doesn’t have that as one of the display options. It’s insanely graphic intensive to do that, so it wasn’t high on the list of optional services. That’s also one reason why Audacity doesn’t scrub.
Other free audio software will do that , e.g. … http://www.sonicvisualiser.org/
but IMO it’s not a helpful feature : it’s far more difficult to focus on a continuously-moving waveform scrolling-by, than on a stationary-waveform , see … https://youtu.be/LbgE_PCAQRg?t=10m05s
[ also a continuously scrolling display will cause the waterfall-illusion … https://youtu.be/oNhcpOIQCNs#t=5s ]
Depends on what you’re doing.
If you use Audacity as a scope, having a fixed playhead is the only way to go if you’re looking for a certain phenomenon in the wave form while recording. In these cases, staring at a moving wave form is extremely tiresome :laughing:
It’s also the reason why some tools even show incoming waves without recording.
2.1.1 does http://manual.audacityteam.org/o/man/scrubbing_and_seeking.html.
I added gLaZe’s “vote” on http://wiki.audacityteam.org/wiki/Feature_Requests for “Smoother Track scrolling on Playback: Keep the cursor in one place but move the track”.
