Possible BUG with Audacity 2.3.3
Hi:
I’m trying to create a Macro around the Graphic EQ effect in Audacity 2.3.3 for the Mac. I’m running MacOS 10.12.6 on a 27" 5K iMac.
When I create the Macro, and add the Graphic EQ effect, it brings along the settings from the last time that I used it. So I go to the edit button, change the Graphic EQ settings and close the window. Then I press the OK button, which I guess acts like a “save” button. The problem is that if I then open the Macro window again, select the Macro that I just created and press the edit button, my settings are back to the original ones that I just changed.
In other words it’s not saving the actual settings created within the Macro window.
Any ideas?
It is a bug. It has now been fixed and the fix will be available in the next Audacity release (scheduled for around the end of April).
