First some background on myself… I’m an electronics engineer, I’ve been using computers for the last 20 years or so (I’m only 30, but I started playing around with them quite early
). I started with DOS, then windows, like most ppl. For the last 12/13 years I’ve been using mostly Linux on all my desktop PCs and laptops, except for the last two years, since I bought a Mac laptop.
I still use desktop PCs, all of them running Linux (and very rarely windows xp). For the last 10 years I’ve owned and used a Toshiba laptop running win98 and linux for most of the time, and more recently win xp and linux (I still use it occasionally, for some “dirty” jobs in harsh environments).
Windows has been, for a long time, the OS I feel less comfortable with… It’s the one I have more difficulty using and in which I take more time to do whatever I need too and the one that makes me feel frustrated more often… (most ppl say windows is the most easy OS to use, I feel exactly the opposite… which proves my theory that the easier OS to use is the one you’re more used to…)
Now the interesting story… two years ago I felt I needed a new laptop… I went searching for a new one to find out that most laptops only had that awful glossy screen which I hate… (I never understood that thing about glossy screens…) So after searching a lot I could only find two laptops that would fulfill my hardware requirements, namely the non-glossy screen… My two options were either a macbookpro or an hp from the business line… Surprisingly, the Mac was actually cheaper than the HP, and its hardware was even slightly better… plus I wasn’t paying for an OS I wasn’t going to use… (windows) At this point my plans were to install linux on it regardless it was a mac or not.
I naturally ended up buying the mac. I’ve been using it for the last 2 years and I’m very very happy with it! I never got to install linux on it… I got used to the MacOS-X quite easily and quickly, I think it’s a wonderful OS, it’s as robust (or even more) as linux and it has all the simplicity, usability and eye-candy that linux never quite had and that microsoft has always been trying to copy from it and then presenting like if it was their invention…
In terms of design and those little details that make a different the mac is absolutely wonderful… The multi-touch touchpad is amazing… after you get used to it you’ll never what other thing… I never felt the need to add an external mouse to my mac like I always did with any other laptop I’ve used… My father has an hp laptop with windows vista I think… the touch pad is supposed to have a scroll function on the side… which sometimes works… and sometimes don’t… I always get quite stressed every time I try to use it… The magnetic plug for the power cord in the mac is one of the best inventions ever! It has saved my laptop from falling to the floor a few times… and there’s a lot more of other interesting and useful small details/features on the mac that I would have a hard time living without now…
HP support is usually good, but Apple’s support is definitely the best I’ve seen…
That said I can only but recommend everyone to get a Mac laptop… Yes they’re more expensive than most consumer level laptops… but if you go for business line of laptops the Mac might actually be cheaper…
When it comes to hardware reliability regardless of the OS… I can’t say Macs are more reliable, they also fail… like other brands do… There is no faulty-free brand… Some brands might be slightly more reliable than others… But the most important here I think it’s the support service, and Apple’s so far has impressed me… but YMMV
Now a few tips on choosing your laptop… you should make a list of requirements you need and then try to narrow your options based on those requirements… things like screen size, max. weight, battery life… things you need (cd-rw), things you don’t need… etc…
