Pops and clicks in playback
I’m running Ubuntu 14.04 and Audacity 2.0.5, during editing of a sound file if I delete a section of sound and then save without moving the position of the editing line. A click is introduced to the sound file about every 1 or 0.5 seconds. If I delete a section of sound and then move the editing line to a different position along the sound wave I don’t get the clicking sound. Is this a bug within Audacity or something within the workings of Ubunu. If I forget to move the editing line before saving and a clicking sound is introduced during playback. I have to shut down Audacity and then reboot it to get rid of this clicking sound. Examining the sound wave when the clicking sound is present I don’t see any indication of anything added to give a clicking sound so it must be associated with a bug within the program.
In case any of these clicks are permanent or some players produce the clicks and some don’t, please be aware of the following good editing practices: http://manual.audacityteam.org/o/man/faq_editing.html#clicks . Definitely Normalize the file with DC offset removal on, before editing it.
Other than that it must be a playback problem. Please post the complete information from Help > Audio Device Info… .
My clicks are not permanent. Also they repeat every 1 or 1.5 seconds as I play the audio file. When I shut down the program and then restart there are no clicks. So it is related only with the program and not with the audio file.
Here is the audio device info
Default capture device number: 10
Default playback device number: 10
Device ID: 0
Device name: HDA Intel PCH: 92HD87B1/3 Analog (hw:0,0)
Host name: ALSA
Input channels: 2
Output channels: 2
Low Input Latency: 0.005805
Low Output Latency: 0.005805
High Input Latency: 0.034830
High Output Latency: 0.034830
Supported Rates:
    44100
    48000
    88200
    96000
    192000
Device ID: 1
Device name: HDA Intel PCH: HDMI 0 (hw:0,3)
Host name: ALSA
Input channels: 0
Output channels: 8
Low Input Latency: -1.000000
High Input Latency: -1.000000
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 2
Device name: sysdefault
Host name: ALSA
Input channels: 128
Output channels: 128
Low Input Latency: 0.021333
Low Output Latency: 0.021333
High Input Latency: 0.021333
High Output Latency: 0.021333
Supported Rates:
    8000
    9600
    11025
    16000
    22050
    32000
    44100
    48000
    88200
    176400
    352800
Device ID: 3
Device name: front
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
    44100
    48000
    88200
    96000
    192000
Device ID: 4
Device name: surround40
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
    44100
    48000
    88200
    96000
    192000
Device ID: 5
Device name: surround51
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
    44100
    48000
    88200
    96000
    192000
Device ID: 6
Device name: surround71
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
    44100
    48000
    88200
    96000
    192000
Device ID: 7
Device name: hdmi
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 8
Device name: pulse
Host name: ALSA
Input channels: 32
Output channels: 32
Low Input Latency: 0.008707
Low Output Latency: 0.008707
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 9
Device name: dmix
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
    48000
Device ID: 10
Device name: default
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Selected capture device: 10 - default
Selected playback device: 10 - default
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Available mixers:
Available capture sources:
Available playback volumes:
0 - Master:0
1 - Headphone:0
2 - Speaker:0
3 - PCM:0
4 - Mic:0
5 - Mic Boost:0
6 - Beep:0
7 - Internal Mic Boost:0
Capture volume is emulated
Playback volume is native
In the device toolbar, try selecting “HDA Intel PCH: 92HD87B1/3 Analog (hw:0,0)” as the recording input device and “front” as the output playback device.
Note that with these settings there must be no other audio applications running, and if you have been watching video in your web browser you may need to close your web browser (to unload Flash), though it should be OK to then re-open your web browser providing that you don’t open a page that plays audio.
