poor sound quality recording & after recording
Hello to all
this is my first post to the forum. I hope someone can answer it.
My OS is win7, My USB Turntable came with a cd so I installed Audicity from there but up dated it online to version 2.
I recently purchased a Tevion USB Turntable to copy all my Albums onto my PC. It uses a standard USB cable to connect to PC.
When I play records via an audio system using the RCA red and white cable the sound is as it should be, of good album quality.
When I connect the USB from turntable to PC and play a record the sound is quite distorted and not like the quality I was getting from audio system.
When I record the music and listen to playback its still the same poor sound.
I played recording in mp3 and wav and still the same.
This is just out of the box
If anyone could help me get a good quality sound if would be very much appreciated
thanx
mrdon
Does Audacity look anything like that when you’re recording?
http://kozco.com/tech/audacity/Audacity1_record.jpg
Grab the right edge of the meters and pull to the right to make them bigger. They may become important for testing.
Post a sample of the distorted audio.
https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
You should probably look to see if you’re recording from the USB connection.
Audacity > Edit > Preferences > Devices > Recording > Device.
If you have a desktop computer, with the appropriate cable/adapter you can connect the turntable’s line-output (RCA connectors) to your soundcard’s line-in (usually color coded blue) and record using your regular soundcard instead of the turntable’s built-in USB soundcard. (Most laptops don’t have line-in.)
That should not be necessary, but it’s an option if you have a soundcard with line-in…
http://www.kozco.com/tech/audacity/pix/soundCardFinal2.jpg
Blue is Stereo Line-In many times.
Hey Koz and dvddoug
we got sorted.
I was recording from the usb cable connection but I think this is a poor way to transfer the music.
I connected to PC via RCA cables as you suggested as I had an adaptor and changed a setting or 2 on input and output and it worked.
I saved then in several formats and then played back and sound is crisp.
So many thanx to the 3 replies
cheers
mrdon
Glad you got it sorted – although it’s supposed to work the reverse. Most computer sound cards have noisy sound and the USB system should sound much better. You might look and see if there is a volume control somewhere on the turntable and if that affects your distortion.
Or not, if you’re happy. We never lose an opportunity to cast seeds of doubt along your path.
