2010 Macbook Pro
Mac OS X 10.6.8
Audacity 2.0.3
Numark MixTrack Pro
Serato Dj Intro
Hello all, I am currently having a bit of trouble making a clear quality recording with my setup… I have a Numark Mixtrack Pro with the 3.5mm audio output end of the red/white RCA cables going into the female end of a female/male/female Y splitter, the male end of the audio splitter is connected to my home stereo system’s aux input, with the other female end of the splitter running a 3.5mm male/male cord into my Macbook Pro’s mic/headphone input.
From there, i open up my sound in system preferences and set up with the following options:
OUTPUT: Select a device for sound output: MixTrack Pro
Use audio port for: Sound Input
INPUT: Select a device for sound output: Line-In
I then select Built-In Output & Built-In Input in Audacity.
Now my purpose for all this is to be able to record a live dj set im mixing, while playing through my home stereo system. The sound quality is fine while im actually playing, but when i finish mixing and listen to the recording, the playback is muffled… im not sure which options to select to acquire clear sound and im a bit frustrated considering I’ve even lowered the input volume in Audacity to make sure that the audio wasn’t clipping… I’ve also used these settings before with no problem and have even tried numerous combinations, i just cant seem to get it right or figure out what has changed to create this problem here. Im hoping I’ve painted a clear enough picture of the chaos that is ensuing on this end. I would absolutely appreciate anyones help : ) Thank you all for your time!
