18:07:15: Audacity 2.0.5
6:07:16 PM: Trying to load FFmpeg libraries...
6:07:16 PM: Trying to load FFmpeg libraries from system paths. File name is 'avformat-52.dll'.
6:07:16 PM: Looking up PATH environment variable...
6:07:16 PM: PATH = 'C:Program Files (x86)InteliCLS Client;C:Program FilesInteliCLS Client;C:Program Files (x86)NVIDIA CorporationPhysXCommon;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program FilesIntelIntel(R) Management Engine ComponentsDAL;C:Program FilesIntelIntel(R) Management Engine ComponentsIPT;C:Program Files (x86)IntelIntel(R) Management Engine ComponentsDAL;C:Program Files (x86)IntelIntel(R) Management Engine ComponentsIPT;C:Program Files (x86)QuickTimeQTSystem;C:Program Files (x86)Windows LiveShared'
6:07:16 PM: Checking that '' is in PATH...
6:07:16 PM: FFmpeg directory is in PATH.
6:07:16 PM: Checking for monolithic avformat from 'avformat-52.dll'.
6:07:16 PM: Error: Failed to load shared library 'avformat-52.dll' (error 126: 找不到指定的模块。)
6:07:16 PM: Loading avutil from 'avutil-50.dll'.
6:07:16 PM: Error: Failed to load shared library 'avutil-50.dll' (error 126: 找不到指定的模块。)
6:07:16 PM: Loading avcodec from 'avcodec-52.dll'.
6:07:16 PM: Error: Failed to load shared library 'avcodec-52.dll' (error 126: 找不到指定的模块。)
6:07:16 PM: Loading avformat from 'avformat-52.dll'.
6:07:16 PM: Error: Failed to load FFmpeg libraries.
6:07:16 PM: Error: Failed to find compatible FFmpeg libraries.
only can record up to 2 seconds. plz help
