Plugins
Hello.
My audacity won’t activate the plugins.
I Downloaded a plugin called “Gsnap” and it won’t activate when i press the “enable button”
I tried reinstalling Audacity, but it diden’t work. I also tried download the dll file in 32-bit even tho i use 64-bit but it diden’t work.
Please help :slight_smile:
I searched the forum for “Gsnap” and I found [u]this[/u].
(BTW - It has to be the 32-bit version even if you’re running 64-bit Windows because Audacity is a 32-bit application.)
I already tried the 32-bit version, and it diden’t work :-/
Ensure that you are installing it correctly: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html#vst_install
