XP Professional
LeCab worked for a time; it now shuts Audacity when I click Okay. I ran a system restore, defrag and reinstall but it still happens.
XP Professional
Which Audacity?
That is a bogus version not made by us, so as you suggested in another post, please update to 2.1.1 from http://audacityteam.org/download/windows.
If you have not yet done so, please see Important information for Windows XP users about the security risks of running XP now that Microsoft no longer support it.
If you still have the same problem in 2.1.1 supplied by us, please attach the Audacity Debug Report that will probably be produced after the crash.
2.0.9 installed from zip. LeCab now crashing Audacity when I click on it. Log attached.
primary%3ADocs%2Ff167_appcompat.txt (36 KB)
There has never been a 2.0.9 version of Audacity.
We cannot help you with bogus versions of Audacity made by others. I recommend uninstalling 2.0.9. scanning your computer for viruses and then installing Audacity 2.1.1 supplied by us. Download it here: http://audacityteam.org/download/windows.
My mistake. I sent the wrong one. The plugin shuts down with some impulses. Log attached.
primary%3ADocs%2FAudacity_dbgrpt-3196-20020101T074432.zip (60.7 KB)
