Plugin problems loading and appear
Mac OS 10-15-7 Adcty 3.2.5
hello
LOST ! how to get he LADSPA plug in .
and none of the . ny are sohing up but are in the Adcty plug in folder ?
thanks a lot for your help
Windows guy here. The current version of Audacity is 3.3.3 which you can download from here: Audacity ® | Download for Mac OS
I’m also a Windows guy and I’ve never used LADSPA, so I was waiting for someone with a solid answer…
I’m not sure if LADSPA plug-ins work anymore and I suspect they don’t work on 64-bit systems.
This page says:
