Hello !
I wonder if anyone in the forum has tried to install the effect plugin ERA-R that removes reverb from a recording. The plugin is said to work in audacity 2.1.2.
I installed the plugin and in both audacity 2.1.2 and 2.1.3 I get the same behavior, namely that the status of the plugin is “new” and when I set it to “enabled” and press OK, audacity automatically turns it back to the state “new”. As a result the plugin is always in state “new” and it never appears in the effect list.
I tried restarting both audacity and windows, but nothing helps. The plugin has a known bug in the readme file that implies that all network adapters must be enabled, which is my case.
If anyone wants to test if the plugin works in your Audacity, the plugin is free for download here: https://s3-eu-west-1.amazonaws.com/com.accusonus/public/products/era-r/current/ERA-R_v1.0.2-WIN.zip
(it gives you 2 weeks of trial)
If anyone knows how to solve the problem I would be grateful
Thanks,
Ariel//
