Pluggins effects vst issue
hello, i’m having a really bad and anoying issue after uppgrading to audacity 3.6, so, before, in audacity 3,2,0 64 bit vertion, i could select a vst3 effect and preview it live while making adjustments, and then render the clip, i cant do that now. Now in audacity 3,6, i can preview the effect, but not make settings or adjustments in realtime and render the clip, realtime-effects seem useless, because then i cant aply the effect on a selection, so, please help! What can i do, do i need to downgrade, because the openvino effects seem sooooo cool!
Hi! Sorry for this, but this feature has been discontinued in newer versions of Audacity.
I would suggest to place the correct piece of audio within a separate track, use Real Time effects and then render that selected audio clip in audio track.
that seems extreeeeemly clunky! Why cant audacity bring back the feature where you could preview while adjusting settings and then render? That was really good and i need this feature!
